Salta al contenuto principale
RIDGID R84015 X2 Speed Switch Replacement
Cosa ti serve
  1. RIDGID R84015 X2 Speed Switch Replacement, RIDGID R84015 X2 Case Removal: passo 1, immagine 1 di 2 RIDGID R84015 X2 Speed Switch Replacement, RIDGID R84015 X2 Case Removal: passo 1, immagine 2 di 2
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Speed Switch Replacement: passo 2, immagine 1 di 1
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Speed Switch Replacement: passo 3, immagine 1 di 2 RIDGID R84015 X2 Speed Switch Replacement: passo 3, immagine 2 di 2
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Speed Switch Replacement, Speed Switch: passo 4, immagine 1 di 1
    • Locate small metal bar above plastic part of drill.
    • Attempt to move bar back and forth. If it wont move, try to move it while rotating the chuck. If it still will not move, there is a problem with the gears. For help see the Planetary Gear Replacement Guide
  5. RIDGID R84015 X2 Speed Switch Replacement: passo 5, immagine 1 di 2 RIDGID R84015 X2 Speed Switch Replacement: passo 5, immagine 2 di 2
    • If the bar moves, next check the small plastic switch that is numbered 1 and 2.
    • Make sure the small tabs on the underside of the switch that move the bar are intact.
    • Replace switch as needed.
Conclusione
Altre 2 persone hanno completato questa guida.
Evan Long
Membro da: 04/15/10
262 Reputazione
4 Guide realizzate
Cal Poly, Team 15-48, Garner Spring 2010 Membro di Cal Poly, Team 15-48, Garner Spring 2010
CPSU-GARNER-S10S15G48
6 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 3,643
