Salta al contenuto principale
RIDGID R84015 X2 Disassembly
Cosa ti serve
  1. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Case Removal: passo 1, immagine 1 di 2 RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Case Removal: passo 1, immagine 2 di 2
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Disassembly: passo 2, immagine 1 di 1
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Disassembly: passo 3, immagine 1 di 2 RIDGID R84015 X2 Disassembly: passo 3, immagine 2 di 2
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Disassembly: passo 4, immagine 1 di 1
    • With your drill taken apart, move your attention to the trigger and forward reverse switch.
  5. RIDGID R84015 X2 Disassembly: passo 5, immagine 1 di 1
    • Check to see that the forward reverse switch isn't broken.
    • NOTE: small tab on trigger fits into groove on forward reverse switch
  6. RIDGID R84015 X2 Disassembly: passo 6, immagine 1 di 1
    • With the battery attached, check that the wires work when the trigger is pulled.
    • Put multimeter wires here.
    • If wires work and drill doesn't, the problem is with the motor.
  7. RIDGID R84015 X2 Disassembly: passo 7, immagine 1 di 1
    • Make sure plastic is not broken and switch is not stuck.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Brian
Membro da: 04/12/10
97 Reputazione
1 Guida realizzata
Cal Poly, Team 15-48, Garner Spring 2010 Membro di Cal Poly, Team 15-48, Garner Spring 2010
CPSU-GARNER-S10S15G48
6 Membri
10 Guide realizzate
Un commento
I was able to diagnose and fix my problem with my black and decker following your instructions. TY
boxingchaos2011 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 21
Tutti i Tempi: 13,551
