Salta al contenuto principale
RIDGID R2740 Motherboard Replacement
Cosa ti serve
  1. RIDGID R2740 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Unplug your device before proceeding..
  2. RIDGID R2740 Motherboard Replacement: passo 2, immagine 1 di 1
    • Orient the sander so the Air Guard logo is facing you.
    • Remove the single Torx TR20 screw.
  3. RIDGID R2740 Motherboard Replacement: passo 3, immagine 1 di 2 RIDGID R2740 Motherboard Replacement: passo 3, immagine 2 di 2
    • Orient the device with the left side face up.
    • Using a Phillips #1 bit, unscrew the 3 screws which hold the internal casing in place.
    • Gently remove the belt.
    • Using the Torx TR10 bit, unscrew the 10 screws which hold the external casing in place.
  4. RIDGID R2740 Motherboard Replacement: passo 4, immagine 1 di 1
    • Gently pull up on the motherboard chip set, pulling it directly from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 603
