Salta al contenuto principale
RIDGID Belt Sander R2740 Tension Lever Spring Replacement
Cosa ti serve
  1. RIDGID Belt Sander R2740 Tension Lever Spring Replacement, Tension Lever Spring: passo 1, immagine 1 di 1
    • Turn the belt sander so that the RIDGID logo is facing you.
    • Flip the tension lever to the open position so that the tension on the spring is released.
    • Remove any sandpaper that is on the belt sander.
  2. RIDGID Belt Sander R2740 Tension Lever Spring Replacement: passo 2, immagine 1 di 3 RIDGID Belt Sander R2740 Tension Lever Spring Replacement: passo 2, immagine 2 di 3 RIDGID Belt Sander R2740 Tension Lever Spring Replacement: passo 2, immagine 3 di 3
    • Using the T20 Torx Screwdriver, remove the two (2) M4 X 19 mm screws on either side of the the belt tension release lever.
    • Remove the side plate to reveal the spring.
  3. RIDGID Belt Sander R2740 Tension Lever Spring Replacement: passo 3, immagine 1 di 2 RIDGID Belt Sander R2740 Tension Lever Spring Replacement: passo 3, immagine 2 di 2
    • Remove and replace the spring (OD 14.47mm X 38.1mm).
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,681
