Salta al contenuto principale
RIDGID BELT SANDER R2740 Timing Belt Replacement
Cosa ti serve
  1. RIDGID BELT SANDER R2740 Timing Belt Replacement, Timing Belt: passo 1, immagine 1 di 1
    • Orientate the sander so that the timing belt housing is facing you.
    • Remove the 19mm T20 screw from the center of the timing belt housing.
  2. RIDGID BELT SANDER R2740 Timing Belt Replacement: passo 2, immagine 1 di 1
    • Remove the timing belt housing.
  3. RIDGID BELT SANDER R2740 Timing Belt Replacement: passo 3, immagine 1 di 1
    • Use your finger or a screwdriver to apply pressure on the belt away from the sander near one of the small wheels.
    • Rotate the large wheel while applying pressure until the timing belt is free from the wheels.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 23
Tutti i Tempi: 996
