Salta al contenuto principale
RCA Voyager II RCT6773W22 Disassembly
Cosa ti serve
  1. RCA Voyager II RCT6773W22 Disassembly, RCA Voyager II RCT6773W22 Disassembly: passo 1, immagine 1 di 1
    • Have Workstation Prepped
  2. RCA Voyager II RCT6773W22 Disassembly: passo 2, immagine 1 di 1
    • remove the two screws on the top of the device with a PH000 screwdriver
  3. RCA Voyager II RCT6773W22 Disassembly: passo 3, immagine 1 di 1
    • Starting from the top, place pick or plastic tool between the power button and screen edge and push apart slightly.
  4. RCA Voyager II RCT6773W22 Disassembly: passo 4, immagine 1 di 1
    • Run pick across the top to the right and then down the right side and around the rest of the tablet.
    • There is a good amount of space between the bezel and the board. Be gentle, but the risk of breaking components is low.
  5. RCA Voyager II RCT6773W22 Disassembly: passo 5, immagine 1 di 2 RCA Voyager II RCT6773W22 Disassembly: passo 5, immagine 2 di 2
    • lift section out of the black casing from the bottom, lift and remove by pulling away from tablet.
  6. RCA Voyager II RCT6773W22 Disassembly: passo 6, immagine 1 di 1
    • Battery connection (on older models, may be soldered to board)
    • Front Camera
    • Digitizer
    • LCD
    • Speaker
  7. RCA Voyager II RCT6773W22 Disassembly: passo 7, immagine 1 di 1
    • Remove battery Connection First
    • Do not use any metal tools while the battery is plugged in. It may cause a short.
  8. RCA Voyager II RCT6773W22 Disassembly: passo 8, immagine 1 di 1
    • unplug the speaker
  9. RCA Voyager II RCT6773W22 Disassembly: passo 9, immagine 1 di 3 RCA Voyager II RCT6773W22 Disassembly: passo 9, immagine 2 di 3 RCA Voyager II RCT6773W22 Disassembly: passo 9, immagine 3 di 3
    • Lift the black cover over all three flex cables (Camera, LCD, Digitizer) with a plastic tool.
    • The covers are incredibly fragile, and easy to break
    • gently disconnect all three cables with your fingers by pulling slightly
  10. RCA Voyager II RCT6773W22 Disassembly: passo 10, immagine 1 di 1
    • remove the three screws securing the board with your PH000 Screwdriver
  11. RCA Voyager II RCT6773W22 Disassembly: passo 11, immagine 1 di 2 RCA Voyager II RCT6773W22 Disassembly: passo 11, immagine 2 di 2
    • lift the board out gently
    • Do not tug the board out too hard, the antenna cable on the left is soldered in!
    • Fold board over the left side of the tablet and gently remove tape securing antenna to the case. Use a small amount of heat if necessary.
  12. RCA Voyager II RCT6773W22 Disassembly: passo 12, immagine 1 di 2 RCA Voyager II RCT6773W22 Disassembly: passo 12, immagine 2 di 2
    • remove tape from top and bottom of the battery.
    • with a plastic piece, lift battery from adhesive securing it in place.
    • do not use a metal or sharp tool to remove the battery, tearing or puncturing it may cause it to explode or heat rapidly, and may damage your device.
    • The battery is secured directly to the back of the LCD. Exercise caution while removing the battery not to damage the LCD.
    • The battery is soft and somewhat malleable - it can bend slightly without damage.
  13. RCA Voyager II RCT6773W22 Disassembly: passo 13, immagine 1 di 2 RCA Voyager II RCT6773W22 Disassembly: passo 13, immagine 2 di 2
    • Place picks between the lcd and the plastic clips holding it in place.
    • The pick placement to the top left side (near the power button) is smaller and on a corner. I recommend inserting this pick last.
  14. RCA Voyager II RCT6773W22 Disassembly: passo 14, immagine 1 di 1
    • Gently push top right pick down to lift LCD from the clip. Run across the top and right side to further lift LCD.
    • Use picks as needed to separate LCD in other areas.
  15. RCA Voyager II RCT6773W22 Disassembly: passo 15, immagine 1 di 1
    • Once separated and loose, remove picks so you do not damage the LCD while removing it.
    • To remove, lift top of LCD and pull out of case away from the speaker, which is fixed to the digitizer frame.
  16. RCA Voyager II RCT6773W22 Disassembly: passo 16, immagine 1 di 2 RCA Voyager II RCT6773W22 Disassembly: passo 16, immagine 2 di 2
    • to remove Digitizer/Glass from the frame and speaker, slide a pick under a corner between the glass and frame to loosen adhesive
    • If you're having issues loosening the adhesive, use a heat gun around the edges, then try again.
  17. RCA Voyager II RCT6773W22 Disassembly: passo 17, immagine 1 di 1
    • You have completely dismantled the RCA Voyager II
Conclusione
Altre 35 persone hanno completato questa guida.
Chris
Membro da: 01/11/16
2.025 Reputazione
1 Guida realizzata
31 Commenti
what is that flat part that has the little copper bar in the middle. What do you call that?
TheUnchanted Sword - Replica
The LCD has a piece of copper tape on it, is that what you mean?
Sam Goldheart -
Nice Guide. Very Simple and Easy to follow!
Aerial L - Replica
Bonne site merci pour tous je suis très heureux content que entrer dans ce site
diego jamal - Replica
Anyone know which company made this very fragile digitizer for RCA Voyager?
Spock Chen - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 21,559
