Salta al contenuto principale
RCA Visys 25212 Handset Battery Replacement
Cosa ti serve
  1. RCA Visys 25212 Handset Battery Replacement, Handset Battery: passo 1, immagine 1 di 1
    • Place your thumb in the groove on the back of handset. Next, push down with your thumb and then slide the battery cover towards the bottom of the phone to remove the battery cover.
  2. RCA Visys 25212 Handset Battery Replacement: passo 2, immagine 1 di 2 RCA Visys 25212 Handset Battery Replacement: passo 2, immagine 2 di 2
    • To remove the battery, gently pull up on the white connector located on the left side of the phone.
Conclusione
To reassemble your device, follow these instructions in reverse order. Make sure the battery connector is fully seated in the handset before replacing the back cover.
Sandy South
Membro da: 01/26/15
431 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 462
