Salta al contenuto principale
Cosa ti serve
  1. RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: passo 1, immagine 1 di 3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: passo 1, immagine 2 di 3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: passo 1, immagine 3 di 3
    • Remove the 5 screws that secure the control panel (located on the top of the device) by using your small flathead screwdriver.
    • Loosen the panel from the device until you are able to remove it.
  2. RCA Small Wonders Camcorder CC176 Viewfinder Replacement: passo 2, immagine 1 di 3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement: passo 2, immagine 2 di 3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement: passo 2, immagine 3 di 3
    • Remove the remaining 21 screws on the camcorder.
    • Begin separating the plastic casing from the inner components of the device.
  3. RCA Small Wonders Camcorder CC176 Viewfinder Replacement: passo 3, immagine 1 di 2 RCA Small Wonders Camcorder CC176 Viewfinder Replacement: passo 3, immagine 2 di 2
    • Grasping the viewfinder in hand, carefully remove the two screws that secure the mounting device.
    • Locate the gray electrical cord that connects the viewfinder to the inner components of the camera. Gently unplug the gray cord and loosen the viewfinder from the device.
    • Separate the viewfinder from the device and feed the gray cord through the hole in the plastic casing.
Conclusione
Allison Baudoin
Membro da: 05/12/2011
401 Reputazione
4 Guide realizzate
James Madison, Team 2-1, Allen Fall 2011 Membro di James Madison, Team 2-1, Allen Fall 2011
JMU-ALLEN-F11S2G1
2 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,152
