Introduzione
RCA Small Wonders Camcorder cc176 was manufactured in May 1993. Use this guide to remove and replace the speaker on this device.
  1. Remove the small black screws along the edges of the control panel on the top of the device. Pry off the top control panel using the plastic wedge tool. Remove the screw from the front, gray panel located beneath the "Scene Select AE" label.
    • Remove the small black screws along the edges of the control panel on the top of the device.
    • Pry off the top control panel using the plastic wedge tool.
    • Remove the screw from the front, gray panel located beneath the "Scene Select AE" label.
    • Remove the two small black screws on the top of the front, gray panel of the device, above the red AUTOFOCUS letters.
  2. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  3. Turn the device over and remove the two screws securing the front panel of the device.
    • Turn the device over and remove the two screws securing the front panel of the device.
    • Remove the screw securing the primary viewfinder, along the front of the camera.
    • Using a flat plastic tool, pry the entire front panel away from the device.
  4. Gently unplug the grey cord, located underneath the panel, disconnecting the speaker from the inner component of the device. Remove the speaker from the device.
    • Gently unplug the grey cord, located underneath the panel, disconnecting the speaker from the inner component of the device.
    • Remove the speaker from the device.
Conclusione
Allison Baudoin
Membro da: 05/12/2011
401 Reputazione
4 Guide realizzate
James Madison, Team 2-1, Allen Fall 2011 Membro di James Madison, Team 2-1, Allen Fall 2011
JMU-ALLEN-F11S2G1
2 Membri
4 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 720
