Salta al contenuto principale
RCA RP3715A Display Replacement
Cosa ti serve
  1. RCA RP3715A Display Replacement, Reaching the battery terminal.: passo 1, immagine 1 di 2 RCA RP3715A Display Replacement, Reaching the battery terminal.: passo 1, immagine 2 di 2
    • Push down on the clip to release pressure. The pull off the plastic cover.
  2. RCA RP3715A Display Replacement, Replacing the battery: passo 2, immagine 1 di 1
    • Remove the 9-volt battery from the battery terminal.
  3. RCA RP3715A Display Replacement, Getting inside the device.: passo 3, immagine 1 di 1
    • Take out the six screws located on the back of the device.
    • The red screws are 10 mm Phillip's #1. The orange screws are 13 mm Phillips #1.
    • Three screws are located on the back panel. One is located inside the battery carriage.
    • Two screws are located on the on the back panel on the bottom left and right side.
  4. RCA RP3715A Display Replacement, Relieve extension cord tension.: passo 4, immagine 1 di 3 RCA RP3715A Display Replacement, Relieve extension cord tension.: passo 4, immagine 2 di 3 RCA RP3715A Display Replacement, Relieve extension cord tension.: passo 4, immagine 3 di 3
    • Remove the 10 mm Phillip's #1 screw.
    • Then remove the metal reinforcement.
  5. RCA RP3715A Display Replacement: passo 5, immagine 1 di 2 RCA RP3715A Display Replacement: passo 5, immagine 2 di 2
    • Using flathead screwdriver undo the release tabs.
  6. RCA RP3715A Display Replacement: passo 6, immagine 1 di 3 RCA RP3715A Display Replacement: passo 6, immagine 2 di 3 RCA RP3715A Display Replacement: passo 6, immagine 3 di 3
    • Pry the release tabs with a spudger.
    • Start with back of the device on the topside.
  7. RCA RP3715A Display Replacement: passo 7, immagine 1 di 2 RCA RP3715A Display Replacement: passo 7, immagine 2 di 2
    • Pry open both tabs to remove the topside of the clock.
  8. RCA RP3715A Display Replacement, Speaker Replacement: passo 8, immagine 1 di 1
    • Remove the two 10mm Phillip's #1 screws. Also remove the two reinforcements holding the speaker in place.
  9. RCA RP3715A Display Replacement, Detaching the front panel: passo 9, immagine 1 di 1
    • Remove the two 10 mm Phillip's #1 screws.
  10. RCA RP3715A Display Replacement: passo 10, immagine 1 di 1
    • Remove the gray panel from the frame.
  11. RCA RP3715A Display Replacement, Unlatch release tabs: passo 11, immagine 1 di 3 RCA RP3715A Display Replacement, Unlatch release tabs: passo 11, immagine 2 di 3 RCA RP3715A Display Replacement, Unlatch release tabs: passo 11, immagine 3 di 3
    • The two latches located in the picture will help take off the display.
    • Remove the display.
Conclusione
USF Tampa, Team 10-5, Brown Fall 2014 Membro di USF Tampa, Team 10-5, Brown Fall 2014
USFT-BROWN-F14S10G5
3 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 19
Tutti i Tempi: 466
