Salta al contenuto principale
RCA RCR8622 Speaker Replacement
Cosa ti serve
  1. RCA RCR8622 Speaker Replacement, Speaker: passo 1, immagine 1 di 3 RCA RCR8622 Speaker Replacement, Speaker: passo 1, immagine 2 di 3 RCA RCR8622 Speaker Replacement, Speaker: passo 1, immagine 3 di 3
    • Remove the casing. Slide the plastic cover with the graphic off the main base. Be careful and hold both sides.
    • Flip the device over and unscrew the five 11 mm screws with a Phillip's #1 screwdriver.
    • A magnetic screwdriver will help you remove the screws from their slots.
  2. RCA RCR8622 Speaker Replacement: passo 2, immagine 1 di 3 RCA RCR8622 Speaker Replacement: passo 2, immagine 2 di 3 RCA RCR8622 Speaker Replacement: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Pull the top of the device off and look closely at the motherboard. You will see two speakers, one on each side of the device.
    • Grab the tweezers and follow the red and black wires leading from the speaker to the motherboard. They will attach to a white casing. Lift the white plug out with the tweezers to disconnect.
  3. RCA RCR8622 Speaker Replacement: passo 3, immagine 1 di 2 RCA RCR8622 Speaker Replacement: passo 3, immagine 2 di 2
    • Grab the speaker and pull upward. The Speakers will be loose.
    • Repeat this step with the other speaker.
Conclusione
Josh Excell
Membro da: 03/20/18
449 Reputazione
4 Guide realizzate
IUPUI, Team S6-G5, Baechle Spring 2018 Membro di IUPUI, Team S6-G5, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G5
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 312
