Salta al contenuto principale
RCA Maven Pro 11 Volume Button Replacement
Cosa ti serve
  1. RCA Maven Pro 11 Volume Button Replacement, Cover: passo 1, immagine 1 di 2 RCA Maven Pro 11 Volume Button Replacement, Cover: passo 1, immagine 2 di 2
    • Remove all the 8 mm Phillips head screws on the side and back of the device.
  2. RCA Maven Pro 11 Volume Button Replacement: passo 2, immagine 1 di 2 RCA Maven Pro 11 Volume Button Replacement: passo 2, immagine 2 di 2
    • Pry off the cover by sticking a wedge in between the screen and the cover.
    • Be careful with the plastic because it can easily break.
    • Once the cover is partly removed, use your hands to take off the rest of the cover.
  3. RCA Maven Pro 11 Volume Button Replacement, Volume Button: passo 3, immagine 1 di 2 RCA Maven Pro 11 Volume Button Replacement, Volume Button: passo 3, immagine 2 di 2
    • Locate the volume button on the inside of the cover.
    • Slide a wedge between the cover and the volume button and lightly lift it off.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 126
