Salta al contenuto principale
RCA Maven Pro 11 Motherboard Replacement
Cosa ti serve
  1. RCA Maven Pro 11 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 3 RCA Maven Pro 11 Motherboard Replacement, Motherboard: passo 1, immagine 2 di 3 RCA Maven Pro 11 Motherboard Replacement, Motherboard: passo 1, immagine 3 di 3
    • Use a Phillip's head screwdriver to unscrew the screws that secure the back cover in place. There are 6 screws in total (4 black, 2 silver).
  2. RCA Maven Pro 11 Motherboard Replacement: passo 2, immagine 1 di 3 RCA Maven Pro 11 Motherboard Replacement: passo 2, immagine 2 di 3 RCA Maven Pro 11 Motherboard Replacement: passo 2, immagine 3 di 3
    • Using a prying tool to pry off the back cover of the tablet. To do this, insert the prying tool between the screen and the side of the tablet.
    • Once the prying tool is inserted, run it along the edge of the tablet until the back cover pops off.
  3. RCA Maven Pro 11 Motherboard Replacement: passo 3, immagine 1 di 1
    • Use a Phillips head screwdriver to unscrew the 4 black screws that secure the motherboard to the device.
  4. RCA Maven Pro 11 Motherboard Replacement: passo 4, immagine 1 di 3 RCA Maven Pro 11 Motherboard Replacement: passo 4, immagine 2 di 3 RCA Maven Pro 11 Motherboard Replacement: passo 4, immagine 3 di 3
    • On the long edge of the motherboard, remove all of the ribbon and bundled cables.
    • The ZIF connections are removed by lifting up the small black tab on the connector and simply pulling out the ribbon cable(s).
    • Insert a spudger or plastic opening tool under the lip of the white bundled cable connector(s), and push the connector(s) free.
  5. RCA Maven Pro 11 Motherboard Replacement: passo 5, immagine 1 di 3 RCA Maven Pro 11 Motherboard Replacement: passo 5, immagine 2 di 3 RCA Maven Pro 11 Motherboard Replacement: passo 5, immagine 3 di 3
    • On the short edge of the motherboard, remove the yellow wire. To do this, lift up the clamp and pull out the wire.
  6. RCA Maven Pro 11 Motherboard Replacement: passo 6, immagine 1 di 1
    • Lift motherboard off the back of the tablet.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 561
