Salta al contenuto principale
RCA Lyra X2400 USB port replacement
Cosa ti serve
  1. RCA Lyra X2400 USB port replacement, Screen: passo 1, immagine 1 di 2 RCA Lyra X2400 USB port replacement, Screen: passo 1, immagine 2 di 2
    • Remove the two Phillips screws from the silver cover at the top of the Lyra.
    • Slowly wiggle the silver cover while pulling it away from the device.
  2. RCA Lyra X2400 USB port replacement: passo 2, immagine 1 di 2 RCA Lyra X2400 USB port replacement: passo 2, immagine 2 di 2
    • Remove the two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
    • Pull the silver case from the bottom of the device.
  3. RCA Lyra X2400 USB port replacement: passo 3, immagine 1 di 3 RCA Lyra X2400 USB port replacement: passo 3, immagine 2 di 3 RCA Lyra X2400 USB port replacement: passo 3, immagine 3 di 3
    • Carefully pry up the screen with a plastic opening tool.
    • Disconnect the screen's ribbon cable from the circuit board.
    • Remove the screen.
  4. RCA Lyra X2400 USB port replacement, Motherboard: passo 4, immagine 1 di 2 RCA Lyra X2400 USB port replacement, Motherboard: passo 4, immagine 2 di 2
    • Open the case of the Lyra.
    • Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
  5. RCA Lyra X2400 USB port replacement, USB in/out: passo 5, immagine 1 di 2 RCA Lyra X2400 USB port replacement, USB in/out: passo 5, immagine 2 di 2
    • Locate the USB in/out component on your Lyra X2400. If you are having difficulty locating this component the picture to the left will show you where it is located.
    • Start using solder/desolder tools to remove the USB in/out.
    • Once removed replace it with the new working USB in/out.
    • Use the soldering tools to reattach the component back to the main logic board.
Conclusione
Joseph Goodwin
Membro da: 04/11/13
1 Reputazione
5 Guide realizzate
Cal Poly, Team 17-3, Regan Spring 2013 Membro di Cal Poly, Team 17-3, Regan Spring 2013
CPSU-REGAN-S13S17G3
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 235
