Salta al contenuto principale
RCA Lyra X2400 Microphone Replacement
Cosa ti serve
  1. RCA Lyra X2400 Microphone Replacement, Battery: passo 1, immagine 1 di 3 RCA Lyra X2400 Microphone Replacement, Battery: passo 1, immagine 2 di 3 RCA Lyra X2400 Microphone Replacement, Battery: passo 1, immagine 3 di 3
    • Using slight pressure with your finger on the word "OPEN", slide the battery plate down.
    • Remove the battery plate.
    • Place your finger at the bottom of the battery.
    • Lift up on the battery until it pops out from the LYRA X2400.
  2. RCA Lyra X2400 Microphone Replacement, Screen: passo 2, immagine 1 di 2 RCA Lyra X2400 Microphone Replacement, Screen: passo 2, immagine 2 di 2
    • Remove the two Phillips screws from the silver cover at the top of the Lyra.
    • Slowly wiggle the silver cover while pulling it away from the device.
  3. RCA Lyra X2400 Microphone Replacement: passo 3, immagine 1 di 2 RCA Lyra X2400 Microphone Replacement: passo 3, immagine 2 di 2
    • Remove the two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
    • Pull the silver case from the bottom of the device.
  4. RCA Lyra X2400 Microphone Replacement: passo 4, immagine 1 di 3 RCA Lyra X2400 Microphone Replacement: passo 4, immagine 2 di 3 RCA Lyra X2400 Microphone Replacement: passo 4, immagine 3 di 3
    • Carefully pry up the screen with a plastic opening tool.
    • Disconnect the screen's ribbon cable from the circuit board.
    • Remove the screen.
  5. RCA Lyra X2400 Microphone Replacement, Motherboard: passo 5, immagine 1 di 2 RCA Lyra X2400 Microphone Replacement, Motherboard: passo 5, immagine 2 di 2
    • Open the case of the Lyra.
    • Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
  6. RCA Lyra X2400 Microphone Replacement, Microphone: passo 6, immagine 1 di 1
    • Locate the microphone component on your Lyra X2400. If you are having difficulty locating this component the picture to the left will show you where it is located.
    • Start using solder/desolder tools to remove the microphone.
    • Once removed replace it with the new working microphone.
    • Use the soldering tools to reattach the component back to the main logic board.
Conclusione
Joseph Goodwin
Membro da: 04/11/13
1 Reputazione
5 Guide realizzate
Cal Poly, Team 17-3, Regan Spring 2013 Membro di Cal Poly, Team 17-3, Regan Spring 2013
CPSU-REGAN-S13S17G3
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 202
