Introduzione
Use this guide to replace the microphone of the RCA Lyra X2400.
Cosa ti serve
Using slight pressure with your finger on the word "OPEN", slide the battery plate down.
Remove the battery plate.
Place your finger at the bottom of the battery.
Lift up on the battery until it pops out from the LYRA X2400.
Remove the two Phillips screws from the silver cover at the top of the Lyra.
Slowly wiggle the silver cover while pulling it away from the device.
Open the case of the Lyra.
Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
Locate the microphone component on your Lyra X2400. If you are having difficulty locating this component the picture to the left will show you where it is located.
Start using solder/desolder tools to remove the microphone.
Once removed replace it with the new working microphone.
Use the soldering tools to reattach the component back to the main logic board.
