Salta al contenuto principale
RCA CC310 Viewfinder Replacement
Cosa ti serve
  1. RCA CC310 Viewfinder Replacement, Viewfinder: passo 1, immagine 1 di 2 RCA CC310 Viewfinder Replacement, Viewfinder: passo 1, immagine 2 di 2
    • Slide a spudger between the plastic rail and the metal tab on the left side of the rail. Push away from the camcorder to release the flap.
    • Pushing the viewfinder assembly to the right makes lifting the flap easier.
    • Slide the lifted flap towards the viewfinder assembly until the viewfinder is free from the rail.
  2. RCA CC310 Viewfinder Replacement: passo 2, immagine 1 di 3 RCA CC310 Viewfinder Replacement: passo 2, immagine 2 di 3 RCA CC310 Viewfinder Replacement: passo 2, immagine 3 di 3
    • Unscrew the 7mm ph#0 screw on the underside where the cable connects.
    • Lift the plastic where the cable connects off of the viewfinder assembly.
    • Disconnect the cable inside by pulling it apart.
  3. RCA CC310 Viewfinder Replacement: passo 3, immagine 1 di 2 RCA CC310 Viewfinder Replacement: passo 3, immagine 2 di 2
    • Unscrew two 7.0mm ph#0 screws on the underside of the viewfinder assembly.
    • Lift the viewfinder plastic assembly up and remove.
  4. RCA CC310 Viewfinder Replacement: passo 4, immagine 1 di 1
    • Flip back the viewfinder access tab.
    • Unscrew the 7.0mm ph #0 screw next to the mirror.
  5. RCA CC310 Viewfinder Replacement: passo 5, immagine 1 di 3 RCA CC310 Viewfinder Replacement: passo 5, immagine 2 di 3 RCA CC310 Viewfinder Replacement: passo 5, immagine 3 di 3
    • Lift off both sides of the plastic assembly.
    • When reassembling, if the housing doesn't connect properly, try turning the focus wheel.
  6. RCA CC310 Viewfinder Replacement: passo 6, immagine 1 di 2 RCA CC310 Viewfinder Replacement: passo 6, immagine 2 di 2
    • Lift the microphone circuit board straight up.
    • Unclip the cable connected to the circuit board.
  7. RCA CC310 Viewfinder Replacement: passo 7, immagine 1 di 3 RCA CC310 Viewfinder Replacement: passo 7, immagine 2 di 3 RCA CC310 Viewfinder Replacement: passo 7, immagine 3 di 3
    • Lift plastic housing and guide the wires from underneath.
    • Lift out the entire circuit board and viewfinder.
    • Replace entire circuit board and viewfinder assembly.
Conclusione
Oliver Adams
Membro da: 01/19/11
629 Reputazione
6 Guide realizzate
Cal Poly, Team 5-20, Amido Winter 2011 Membro di Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Membri
7 Guide realizzate
1Commento della guida
do you know where i can find a relacement one of these parts
Connor Byrley - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,555
