Introduzione
Replacing the onboard speaker for the RCA CC310.
  1. Remove the 6-7.9mm ph#0 screws on the back and bottom.
    • Remove the 6-7.9mm ph#0 screws on the back and bottom.
    • Remove the one 3.8mm ph#0 screw on the bottom.
    • Remove the two 7.5mm ph#0 screws on the back and bottom.
  2. Remove 5.8mm ph#1 screw from the side button panel.
    • Remove 5.8mm ph#1 screw from the side button panel.
    • Slide the viewfinder all the way to the right and remove the 7.9mm ph#0 screw.
    • Pry along the seam on the top side near the buttons with a spudger.
    • Pull the left panel away from the rest of the camcorder.
    • Unplug the red speaker cable located at the rear of the device.
    • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
    • Unplug the red cable connecting the speaker to the motherboard.
    • Locate the speaker on the removed panel. Find the groove on the top left side of the speaker.
    • Pry the plastic up with a spudger until the glue breaks and the speaker is detached.
    • Break the plastic pieces holding the cable to the panel.
    • Glue the new cables, with a hot glue gun, back to the panel after replacing the speaker.
    • Glue the new speaker to the panel.
    • Plug the cable back into the motherboard.
Conclusione
Oliver Adams
Membro da: 19/01/2011
620 Reputazione
6 Guide realizzate
Cal Poly, Team 5-20, Amido Winter 2011 Membro di Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Membri
7 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 818
