Salta al contenuto principale
RCA CC310 Onboard Microphone Replacement
Cosa ti serve
  1. RCA CC310 Onboard Microphone Replacement, Onboard Microphone: passo 1, immagine 1 di 2 RCA CC310 Onboard Microphone Replacement, Onboard Microphone: passo 1, immagine 2 di 2
    • Lift the metal flap and slide the viewfinder off to the right.
  2. RCA CC310 Onboard Microphone Replacement: passo 2, immagine 1 di 3 RCA CC310 Onboard Microphone Replacement: passo 2, immagine 2 di 3 RCA CC310 Onboard Microphone Replacement: passo 2, immagine 3 di 3
    • Unscrew the 7.0mm ph#0 screw on the underside where the cable connects.
    • Lift the plastic where the cable is connected to the viewfinder.
    • Disconnect the cable inside by pulling it apart.
  3. RCA CC310 Onboard Microphone Replacement: passo 3, immagine 1 di 2 RCA CC310 Onboard Microphone Replacement: passo 3, immagine 2 di 2
    • Unscrew the two 7mm ph#0 screws on the underside of the viewfinder assembly.
    • Lift the viewfinder plastic assembly up.
  4. RCA CC310 Onboard Microphone Replacement: passo 4, immagine 1 di 2 RCA CC310 Onboard Microphone Replacement: passo 4, immagine 2 di 2
    • Lift the microphone circuit board straight up.
    • Unclip the cable connected to the circuit board.
  5. RCA CC310 Onboard Microphone Replacement: passo 5, immagine 1 di 1
    • Turn the microphone circuit board over.
    • Unscrew the two Ph#0 screws holding the plastic housing on the circuit board.
  6. RCA CC310 Onboard Microphone Replacement: passo 6, immagine 1 di 1
    • Desolder the metal protective housing using a soldering iron.
    • Desolder the microphone and replace it.
Conclusione
Oliver Adams
Membro da: 01/19/11
629 Reputazione
6 Guide realizzate
Cal Poly, Team 5-20, Amido Winter 2011 Membro di Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 912
