Salta al contenuto principale
RCA CC310 Main Motherboard Replacement
Cosa ti serve
  1. RCA CC310 Main Motherboard Replacement, Disassembling RCA CC310 Left Cover: passo 1, immagine 1 di 2 RCA CC310 Main Motherboard Replacement, Disassembling RCA CC310 Left Cover: passo 1, immagine 2 di 2
    • Remove the six 7.9mm Phillips #0 screws on the back and bottom.
    • Remove the one 3.8mm Phillips #0 screw on the bottom.
    • Remove the two 7.5mm Phillips #0 screws on the back and bottom.
  2. RCA CC310 Main Motherboard Replacement: passo 2, immagine 1 di 2 RCA CC310 Main Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove 5.8mm Phillips #1 screw from the side button panel.
    • Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
  3. RCA CC310 Main Motherboard Replacement: passo 3, immagine 1 di 2 RCA CC310 Main Motherboard Replacement: passo 3, immagine 2 di 2
    • Pry along the seam on the top side near the buttons with a spudger.
  4. RCA CC310 Main Motherboard Replacement: passo 4, immagine 1 di 2 RCA CC310 Main Motherboard Replacement: passo 4, immagine 2 di 2
    • Pull the left panel away from the rest of the camcorder.
    • Unplug the red speaker cable located at the rear of the device.
    • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
  5. RCA CC310 Main Motherboard Replacement, Main Motherboard: passo 5, immagine 1 di 2 RCA CC310 Main Motherboard Replacement, Main Motherboard: passo 5, immagine 2 di 2
    • Pull back the plastic tabs along the edges of the motherboard.
    • Disconnect all the cables along the left side of the motherboard.
  6. RCA CC310 Main Motherboard Replacement: passo 6, immagine 1 di 2 RCA CC310 Main Motherboard Replacement: passo 6, immagine 2 di 2
    • Disconnect all cables along the bottom of the motherboard.
    • Pull the motherboard away from the camcorder.
  7. RCA CC310 Main Motherboard Replacement: passo 7, immagine 1 di 1
    • Desolder the two black wires holding the motherboard to the camcorder using a soldering iron.
Conclusione
Oliver Adams
Membro da: 01/19/11
629 Reputazione
6 Guide realizzate
Cal Poly, Team 5-20, Amido Winter 2011 Membro di Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,690
