Introduzione
If you have any problems due to a bad motherboard, this guide will instruct you how to replace it.
  1. Remove the 6-7.9mm ph#0 screws on the back and bottom.
    • Remove the 6-7.9mm ph#0 screws on the back and bottom.
    • Remove the one 3.8mm ph#0 screw on the bottom.
    • Remove the two 7.5mm ph#0 screws on the back and bottom.
  2. Remove 5.8mm ph#1 screw from the side button panel.
    • Remove 5.8mm ph#1 screw from the side button panel.
    • Slide the viewfinder all the way to the right and remove the 7.9mm ph#0 screw.
    • Pry along the seam on the top side near the buttons with a spudger.
    • Pull the left panel away from the rest of the camcorder.
    • Unplug the red speaker cable located at the rear of the device.
    • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
    • Pull back the plastic tabs along the edges of the motherboard.
    • Disconnect all the cables along the left side of the motherboard.
    • Disconnect all cables along the bottom of the motherboard.
    • Pull the motherboard away from the camcorder.
    • Desolder the two black wires holding the motherboard to the camcorder using a soldering iron.
Conclusione
Oliver Adams
Membro da: 19/01/2011
620 Reputazione
6 Guide realizzate
Cal Poly, Team 5-20, Amido Winter 2011 Membro di Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Membri
7 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,187
