Salta al contenuto principale
RCA 8 Apollo Back Panel Replacement
Cosa ti serve
  1. RCA 8 Apollo Back Panel Replacement, Back Panel: passo 1, immagine 1 di 1
    • Before you begin, discharge your tablet battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your tablet before beginning to disassemble.
  2. RCA 8 Apollo Back Panel Replacement: passo 2, immagine 1 di 2 RCA 8 Apollo Back Panel Replacement: passo 2, immagine 2 di 2
    • Insert an iFixit opening tool into the gap between the tablet and back panel.
    • Using a combination of iFixit opening tools and iFixit opening picks, pry the tablet upward around its perimeter to release it from the plastic rear case.
    • If inserted too far, an opening pick can damage your device. It is helpful to mark the edge with an opening pick, or opening tool at a depth that will not damage the inner contents of the tablet.
  3. RCA 8 Apollo Back Panel Replacement: passo 3, immagine 1 di 2 RCA 8 Apollo Back Panel Replacement: passo 3, immagine 2 di 2
    • Disconnect the red and black speaker wires from the tablet.
    • The front and back of the tablet will be disconnected.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 118
