Salta al contenuto principale
RCA 22” DECK215R HDTV Optical Reader Replacement
Cosa ti serve
  1. RCA 22” DECK215R HDTV Optical Reader Replacement, Removing the Stand: passo 1, immagine 1 di 2 RCA 22” DECK215R HDTV Optical Reader Replacement, Removing the Stand: passo 1, immagine 2 di 2
    • Before disassembling your television, ensure that all cables are unplugged from their power source to avoid serious injury or death from electrocution.
    • Lay the TV flat with the screen facing down.
    • Remove the four, 12mm Phillips #2 screws from the back of the TV stand. Support the TV from underneath as you remove the screws, so the bottom does not fall on the table.
    • Remove the stand by lifting it away from the TV's backing.
  2. RCA 22” DECK215R HDTV Optical Reader Replacement, Removing the Back Panel: passo 2, immagine 1 di 2 RCA 22” DECK215R HDTV Optical Reader Replacement, Removing the Back Panel: passo 2, immagine 2 di 2
    • Remove the twelve, 6mm Phillips #2 screws from the middle of the TV's rear casing.
    • Remove the seven, 9mm Phillips #2 screws from the outer edge of the TV's rear casing.
    • While holding the screen down, pull the back panel up slowly, ensuring that you do not forcibly disconnect the remaining ribbon cable.
  3. RCA 22” DECK215R HDTV Optical Reader Replacement, Locate Pin: passo 3, immagine 1 di 1
    • Position the television to where the back panel is resting on the table and the screen is vertical.
    • Peel the tape covering the ribbon cable horizontally.
  4. RCA 22” DECK215R HDTV Optical Reader Replacement: passo 4, immagine 1 di 3 RCA 22” DECK215R HDTV Optical Reader Replacement: passo 4, immagine 2 di 3 RCA 22” DECK215R HDTV Optical Reader Replacement: passo 4, immagine 3 di 3
    • Pinch the clamps on both sides of the ribbon cable casing to detach it from the screen panel.
    • Remove the screen to isolate the back panel.
  5. RCA 22” DECK215R HDTV Optical Reader Replacement, Detaching the Motherboard: passo 5, immagine 1 di 2 RCA 22” DECK215R HDTV Optical Reader Replacement, Detaching the Motherboard: passo 5, immagine 2 di 2
    • Identify the motherboard in the rear casing.
    • Remove the ground cable from the motherboard by gently lifting it up as shown.
    • Remove the six 6mm Phillips #2 screws from the perimeter of the motherboard.
  6. RCA 22” DECK215R HDTV Optical Reader Replacement, Preparing the Motherboard for Replacement: passo 6, immagine 1 di 3 RCA 22” DECK215R HDTV Optical Reader Replacement, Preparing the Motherboard for Replacement: passo 6, immagine 2 di 3 RCA 22” DECK215R HDTV Optical Reader Replacement, Preparing the Motherboard for Replacement: passo 6, immagine 3 di 3
    • Caution: Before you remove the motherboard, be cautious of the many capacitors throughout that could cause serious injury or death. Use a discharge probe to safely rid the capacitors of dangerous charges. The following link provides an instructional video for how to properly complete this step: https://www.youtube.com/watch?v=M-AIbrbT....
    • Wearing rubber gloves and rubber soled shoes while working with and near the capacitors ensures greater safety and protection against electric shock. See iFixit's Project Safety page for additional safety information.
    • Remove the motherboard by gripping the rubber stopper as shown and lifting the motherboard up out of its plastic housing.
    • Carefully flip the motherboard over and locate the nineteen capacitors.
    • Notice the six cables attached to the motherboard. Pull on each cable connector with moderate to heavy force to remove them.
  7. RCA 22” DECK215R HDTV Optical Reader Replacement, Removing the CD Drive: passo 7, immagine 1 di 3 RCA 22” DECK215R HDTV Optical Reader Replacement, Removing the CD Drive: passo 7, immagine 2 di 3 RCA 22” DECK215R HDTV Optical Reader Replacement, Removing the CD Drive: passo 7, immagine 3 di 3
    • Remove the four 11mm Phillips #2 screws from each corner of the DVD drive plastic casing.
    • Untuck the cable consisting of five gray wires from underneath the black circuit board.
    • Lift the DVD drive up out of its plastic housing as shown.
  8. RCA 22” DECK215R HDTV Optical Reader Replacement, Removing the Circuit Board: passo 8, immagine 1 di 3 RCA 22” DECK215R HDTV Optical Reader Replacement, Removing the Circuit Board: passo 8, immagine 2 di 3 RCA 22” DECK215R HDTV Optical Reader Replacement, Removing the Circuit Board: passo 8, immagine 3 di 3
    • This step involves working around capacitors. Before you remove the circuit board, be cautious of the many capacitors throughout that could cause serious injury or death. The following link provides an instructional video for how to properly complete this step: https://www.youtube.com/watch?v=M-AIbrbT....
    • Remove the two 6mm Phillips #0 screws from the green circuit board.
    • Lift the circuit board up to remove it from the rest of the DVD drive.
  9. RCA 22” DECK215R HDTV Optical Reader Replacement, Removing the Optical Reader: passo 9, immagine 1 di 3 RCA 22” DECK215R HDTV Optical Reader Replacement, Removing the Optical Reader: passo 9, immagine 2 di 3 RCA 22” DECK215R HDTV Optical Reader Replacement, Removing the Optical Reader: passo 9, immagine 3 di 3
    • Remove the three 11mm T6 torx screws from the ends of the optical reader railings.
    • Lift the railings and optical reader out of their metal housing.
Conclusione
Cal Poly, Team 70-2, Forte Winter 2015 Membro di Cal Poly, Team 70-2, Forte Winter 2015
CPSU-FORTE-W15S70G2
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 470
