Salta al contenuto principale
RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement
Cosa ti serve
  1. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Backplate: passo 1, immagine 1 di 3 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Backplate: passo 1, immagine 2 di 3 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Backplate: passo 1, immagine 3 di 3
    • Remove the three Phillips #00 screws at the bottom of the device.
  2. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 2, immagine 1 di 2 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove the two Phillips #00 screws to the left and right of the keyboard connector.
  3. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 3, immagine 1 di 1
    • Pull on one of the bottom corners to begin to pull off the back plate.
  4. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 4, immagine 1 di 2 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 4, immagine 2 di 2
    • Work around the outside of the chassis, using the spudger to pry the backplate off.
    • After doing this for about half the device, the backplate should pop right off.
  5. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Battery: passo 5, immagine 1 di 1
    • Remove the tape over the connectors on the motherboard and other side of the battery.
  6. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 6, immagine 1 di 1
    • Disconnect the red and black keyboard wires connecting the battery to the motherboard.
  7. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 7, immagine 1 di 1
    • Disconnect the black ribbon cable running over the battery. Flip up the black clamp and pull the cable out.
  8. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 8, immagine 1 di 2 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 8, immagine 2 di 2
    • Remove the cable over the battery connecting the motherboard and the power connector.
    • Flip up the black clamp and pull the cable out.
  9. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 9, immagine 1 di 2 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 9, immagine 2 di 2
    • Pull out battery. It is taped to the device so it is safe to pull out.
    • Look for damage to the battery. If damaged, make sure to not get any acid on your fingers.
  10. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Antenna: passo 10, immagine 1 di 1
    • Identify the grey wire on the right side of the device.
  11. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 11, immagine 1 di 1
    • Remove the orange ribbon cable over the wire.
  12. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 12, immagine 1 di 1
    • Remove the antenna using a soldering iron.
  13. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Motherboard: passo 13, immagine 1 di 1
    • Remove the blue and black wire from the top of the motherboard.
  14. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 14, immagine 1 di 1
    • Remove the screws from the motherboard.
  15. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 15, immagine 1 di 1
    • Remove the motherboard.
Conclusione
Marcus Elysee
Membro da: 10/25/19
97 Reputazione
1 Guida realizzata
Un commento
Where can I buy this motherboard?
waymond everett - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,354
