Salta al contenuto principale
RCA 10 Viking Pro RCT6K03W13 Antenna Replacement
Cosa ti serve
  1. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement, Backplate: passo 1, immagine 1 di 3 RCA 10 Viking Pro RCT6K03W13 Antenna Replacement, Backplate: passo 1, immagine 2 di 3 RCA 10 Viking Pro RCT6K03W13 Antenna Replacement, Backplate: passo 1, immagine 3 di 3
    • Remove the three Phillips #00 screws at the bottom of the device.
  2. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: passo 2, immagine 1 di 2 RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: passo 2, immagine 2 di 2
    • Remove the two Phillips #00 screws to the left and right of the keyboard connector.
  3. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: passo 3, immagine 1 di 1
    • Pull on one of the bottom corners to begin to pull off the back plate.
  4. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: passo 4, immagine 1 di 2 RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: passo 4, immagine 2 di 2
    • Work around the outside of the chassis, using the spudger to pry the backplate off.
    • After doing this for about half the device, the backplate should pop right off.
  5. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement, Antenna: passo 5, immagine 1 di 1
    • Identify the grey wire on the right side of the device.
  6. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: passo 6, immagine 1 di 1
    • Remove the orange ribbon cable over the wire.
  7. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: passo 7, immagine 1 di 1
    • Remove the antenna using a soldering iron.
Conclusione
Ryan Wickett
Membro da: 10/25/19
632 Reputazione
3 Guide realizzate
Un commento
Does anyone know where I can buy a new antenna for this device?
DIY_Human - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 9
Tutti i Tempi: 398
