Salta al contenuto principale
Quiksilver The Fifty50 Back Panel Replacement
Cosa ti serve
  1. Quiksilver The Fifty50 Back Panel Replacement, Strap: passo 1, immagine 1 di 2 Quiksilver The Fifty50 Back Panel Replacement, Strap: passo 1, immagine 2 di 2
    • Place the watch (face down) on a solid surface.
    • Carefully use the screwdriver and push in one side of the strap.
    • Slowly remove the strap by pushing back one of the hidden metallic holders for the strap.
    • If you are having difficulty trying to take off the strap, feel free to use a 3.5 flat head screw driver, or any kind of tool that make this step easier.
  2. Quiksilver The Fifty50 Back Panel Replacement: passo 2, immagine 1 di 2 Quiksilver The Fifty50 Back Panel Replacement: passo 2, immagine 2 di 2
    • Gently pull the pin out of the strap.
    • Carefully handle the small metallic holder, as they are sharp and may be difficult to locate if lost.
  3. Quiksilver The Fifty50 Back Panel Replacement, Back Panel: passo 3, immagine 1 di 2 Quiksilver The Fifty50 Back Panel Replacement, Back Panel: passo 3, immagine 2 di 2
    • Remove the four 1.1 mm screws holding the back panel in place using the Phillips #00 screwdriver.
  4. Quiksilver The Fifty50 Back Panel Replacement: passo 4, immagine 1 di 1
    • Carefully separate the panel off of the watch.
    • Careful not to lose the four 1.1 mm screw or else the back panel will not be able to put back.
Conclusione
Sue Giske
Membro da: 07/16/19
622 Reputazione
5 Guide realizzate
UW Tacoma, Team S1-G4, Liner Summer 2019 Membro di UW Tacoma, Team S1-G4, Liner Summer 2019
UWT-LINER-SU19S1G4
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 196
