Salta al contenuto principale
Quantum View 10.1 camera Replacement
Cosa ti serve
  1. Quantum View 10.1 camera Replacement, Open Quantum View case: passo 1, immagine 1 di 1
    • Start by turning the tablet over with the screen down. Carefully use a plastic opening tool to pry the cover off. Start from the corner opposite the hibernate button.
  2. Quantum View 10.1 camera Replacement, Removing the electrical tape and magnets.: passo 2, immagine 1 di 2 Quantum View 10.1 camera Replacement, Removing the electrical tape and magnets.: passo 2, immagine 2 di 2
    • Pick up the magnets from the bottom edge of the tablet next to the keyboard connection and put them in a place that they will not get lost. Then carefully remove all 4 strips of electrical tape.
  3. Quantum View 10.1 camera Replacement, Unhooking the battery: passo 3, immagine 1 di 2 Quantum View 10.1 camera Replacement, Unhooking the battery: passo 3, immagine 2 di 2
    • Using a small plastic opening tool; genteelly pull the connection off of the motherboard.
    • Remove yellow plastic and carefully pull clip away from connection.
  4. Quantum View 10.1 camera Replacement, Remove camera clip: passo 5, immagine 1 di 2 Quantum View 10.1 camera Replacement, Remove camera clip: passo 5, immagine 2 di 2
    • Remove yellow tape.
    • Unclip ribbon connector.
  5. Quantum View 10.1 camera Replacement, Remove camera: passo 6, immagine 1 di 2 Quantum View 10.1 camera Replacement, Remove camera: passo 6, immagine 2 di 2
    • Unscrew plastic camera holder using a PH00 screwdriver bit.
    • Release the plastic holder tab and remove camera.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 149
