Salta al contenuto principale
Quantum View 10.1 Motherboard Replacement
Cosa ti serve
  1. Quantum View 10.1 Motherboard Replacement, Open Quantum View case: passo 1, immagine 1 di 1
    • Start by turning the tablet over with the screen down. Carefully use a plastic opening tool to pry the cover off. Start from the corner opposite the hibernate button.
  2. Quantum View 10.1 Motherboard Replacement, Removing the electrical tape and magnets.: passo 2, immagine 1 di 2 Quantum View 10.1 Motherboard Replacement, Removing the electrical tape and magnets.: passo 2, immagine 2 di 2
    • Pick up the magnets from the bottom edge of the tablet next to the keyboard connection and put them in a place that they will not get lost. Then carefully remove all 4 strips of electrical tape.
  3. Quantum View 10.1 Motherboard Replacement, Unhooking the battery: passo 3, immagine 1 di 2 Quantum View 10.1 Motherboard Replacement, Unhooking the battery: passo 3, immagine 2 di 2
    • Using a small plastic opening tool; genteelly pull the connection off of the motherboard.
  4. Quantum View 10.1 Motherboard Replacement, Disconnect Cables: passo 4, immagine 1 di 3 Quantum View 10.1 Motherboard Replacement, Disconnect Cables: passo 4, immagine 2 di 3 Quantum View 10.1 Motherboard Replacement, Disconnect Cables: passo 4, immagine 3 di 3
    • Remove silver protective sticker and set to the side.
    • Ensure all ribbon cables and other connectors are disconnected from mother board.
  5. Quantum View 10.1 Motherboard Replacement, Remove Screws: passo 5, immagine 1 di 2 Quantum View 10.1 Motherboard Replacement, Remove Screws: passo 5, immagine 2 di 2
    • There are 4 small screws connecting the motherboard to the frame of the device. Take a PH00 bit screw driver to remove these screws.
  6. Quantum View 10.1 Motherboard Replacement, Remove Motherboard: passo 6, immagine 1 di 1
    • Gently and carefully lift motherboard straight up from frame.
Conclusione
4 Commenti
tell me which battery is suitable ?
Иван Шульга - Replica
Hi
I would like to request for my tablet bios.bin EM_i8211 V6.1 (this code on board )
My tablet is fail bios
Please help me,
Ye Yint Aung - Replica
Hi
My tablet bois missing when it was updating …
MB model is EM_i8211 V6.1
Please help me for find bios file …
tnx alot …
p30emaile@yahoo.com
Nima khalaji - Replica
Hello, I have a CSL Panhter Tab 10 v2 which has the same mainboard. Because my bios is defective, it won't start anymore! My request, could you read the BIOS and attach the ROM.bin to a PM or send me a link. there is simply nothing left to find I would be very grateful
Felix Klein - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,304
