Salta al contenuto principale
Ricambi
Nessuna parte specificata.
  1. Start by turning the tablet over with the screen down. Carefully use a plastic opening tool to pry the cover off. Start from the corner opposite the hibernate button.
    • Start by turning the tablet over with the screen down. Carefully use a plastic opening tool to pry the cover off. Start from the corner opposite the hibernate button.
  2. Pick up the magnets from the bottom edge of the tablet next to the keyboard connection and put them in a place that they will not get lost. Then carefully remove all 4 strips of electrical tape. Pick up the magnets from the bottom edge of the tablet next to the keyboard connection and put them in a place that they will not get lost. Then carefully remove all 4 strips of electrical tape.
    • Pick up the magnets from the bottom edge of the tablet next to the keyboard connection and put them in a place that they will not get lost. Then carefully remove all 4 strips of electrical tape.
  3. Using a small plastic opening tool; genteelly pull the connection off of the motherboard. Using a small plastic opening tool; genteelly pull the connection off of the motherboard.
    • Using a small plastic opening tool; genteelly pull the connection off of the motherboard.
Conclusione
2 Commenti
How do I find a replacement battery?
Chris Clayton - Replica
Seems finding the right battery is a problem
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 594
