Salta al contenuto principale
Qualcomm QCP-2760 Motherboard Replacement
Cosa ti serve
  1. Qualcomm QCP-2760 Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Unscrew the back battery plate from the phone using a T6 Torx screwdriver.
    • The screw does not need to be removed completely, the back battery plate will unhinge from the phone.
  2. Qualcomm QCP-2760 Motherboard Replacement, Rear Backing: passo 2, immagine 1 di 2 Qualcomm QCP-2760 Motherboard Replacement, Rear Backing: passo 2, immagine 2 di 2
    • Using the T6 Torx screwdriver, remove the two screws located at the bottom of the back of the phone.
    • Find the seam between the front and back of the phone
    • Pry the seam open using a plastic opening tool, or your fingers.
    • Some force is required
  3. Qualcomm QCP-2760 Motherboard Replacement, Motherboard: passo 3, immagine 1 di 1
    • Locate the four metal clips holding the motherboard onto the phone.
    • Pull the clips away from the motherboard while lifting the motherboard out of the case.
    • The motherboard is attached to the case by a fragile cable, do not apply any stress to the cable.
  4. Qualcomm QCP-2760 Motherboard Replacement: passo 4, immagine 1 di 2 Qualcomm QCP-2760 Motherboard Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Place the motherboard down so that the screen is facing up.
    • Grab the small brown connector plug at the sides with a fingernail or tweezers and flip it up.
    • Locate, but do not disconnect, the four screen clips.
  5. Qualcomm QCP-2760 Motherboard Replacement: passo 5, immagine 1 di 2 Qualcomm QCP-2760 Motherboard Replacement: passo 5, immagine 2 di 2
    • Flip the motherboard over so that the screen is facing down.
    • Again, be careful not to put stress on the speaker cable.
Conclusione
Graham
Membro da: 09/30/14
107 Reputazione
1 Guida realizzata
Ohio State, Team 1-4, Buehl Fall 2014 Membro di Ohio State, Team 1-4, Buehl Fall 2014
OSU-BUEHL-F14S1G4
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 289
