Salta al contenuto principale
Qanba Crystal Joystick and Buttons Replacement
Cosa ti serve
  1. Qanba Crystal Joystick and Buttons Replacement, Button, Joystick and Artwork: passo 1, immagine 1 di 3 Qanba Crystal Joystick and Buttons Replacement, Button, Joystick and Artwork: passo 1, immagine 2 di 3 Qanba Crystal Joystick and Buttons Replacement, Button, Joystick and Artwork: passo 1, immagine 3 di 3
    • Use the Phillips #1 screwdriver to remove the eight 20 mm screws.
    • Remove the metal plate to gain access to the internals of the device.
  2. Qanba Crystal Joystick and Buttons Replacement: passo 2, immagine 1 di 3 Qanba Crystal Joystick and Buttons Replacement: passo 2, immagine 2 di 3 Qanba Crystal Joystick and Buttons Replacement: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Taking a picture or marking cables with masking tape is advised as it will help with the reassembly process.
    • Each button has three cables, unplug these from each one.
    • The joystick has two cables, unplug both of these.
    • The use of ESD safe tweezers may assist with unplugging the cables.
  3. Qanba Crystal Joystick and Buttons Replacement: passo 3, immagine 1 di 3 Qanba Crystal Joystick and Buttons Replacement: passo 3, immagine 2 di 3 Qanba Crystal Joystick and Buttons Replacement: passo 3, immagine 3 di 3
    • Use the Phillips #1 screwdriver to remove the four 10 mm screws.
    • Use a flathead screwdriver to hold the screw in place.
    • Twist off the ball top of the joystick while holding the screw in place with a screwdriver.
    • Remove the joystick and all of it's components.
  4. Qanba Crystal Joystick and Buttons Replacement: passo 4, immagine 1 di 1
    • Press in the tabs on the top and bottom of the buttons to remove them.
    • The outline of the buttons are sharp, do exercise caution with the removal of the buttons.
  5. Qanba Crystal Joystick and Buttons Replacement: passo 5, immagine 1 di 3 Qanba Crystal Joystick and Buttons Replacement: passo 5, immagine 2 di 3 Qanba Crystal Joystick and Buttons Replacement: passo 5, immagine 3 di 3
    • Flip the controller over.
    • Peel the six shiny stickers and their epoxy glue off of the controller.
    • Remove the six newly revealed Phillips screws.
    • Remove the acrylic panel.
Conclusione
Kevin Vu
Membro da: 06/29/21
121 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 113
Tutti i Tempi: 2,045
