Strumenti
Parti
  1. Start with removing the three screws to open the case. After removing the screws pull/push the case to the backside to remove it.
    • Start with removing the three screws to open the case. After removing the screws pull/push the case to the backside to remove it.
  2. Now you can remove the power supply unit. This requires 5 more screws on the back and two inside the case to be removed.
    • Now you can remove the power supply unit. This requires 5 more screws on the back and two inside the case to be removed.
    • Remove the remaining two screws on the back side. Two more can be found on the bottom and one on the bottom corner left and right. Noch you can careful remove the back of the UX-500P.
    • Now you can remove the final four screws that attaches the 120mm fan to the back of the UX500-P.
Conclusione
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
Chris Klinger
Membro da: 07/05/2016
33 Reputazione
1 Guida realizzata
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 52
