Salta al contenuto principale
QFX IT-437 Battery Replacement
Cosa ti serve
  1. QFX IT-437 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Begin the process by using a PH00 Phillips screw driver.
    • Remove the two 1.2mm x 3mm screws at the bottom of the tablet.
  2. QFX IT-437 Battery Replacement: passo 2, immagine 1 di 2 QFX IT-437 Battery Replacement: passo 2, immagine 2 di 2
    • Use the iFixit plastic opening tool to pry open the back of the tablet.
    • Do not remove the back case completely as tape has to be removed from the wires, and pulling the case apart can tear off the wires.
  3. QFX IT-437 Battery Replacement: passo 3, immagine 1 di 1
    • Remove the tape connecting the battery to the motherboard.
    • Save the tape in good condition for the replacement so the wires do not get stuck in the case.
  4. QFX IT-437 Battery Replacement: passo 4, immagine 1 di 1
    • Remove the black tape attaching the wires to the battery.
  5. QFX IT-437 Battery Replacement: passo 5, immagine 1 di 1
    • Use the plastic opening pick in order to remove the battery from the tablet, and set it aside for the replacement.
    • The removed wires will have to be soldered back on to the motherboard.
Conclusione
Douglas
Membro da: 01/28/15
482 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 399
