Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Pwnagotchi, usa il nostro manuale di assistenza.
    1. Pwnagotchi Teardown, Pwnagotchi Teardown: passo 1, immagine 1 di 1
      • Before removing the casing from the Pwnagotchi, there are two LED's with different functions
      • The green LED is the Rasperry Pi Zero's data indicator. This will flash as the SD card is being read/written to
      • You have the option to disable the LED if you connect to your Pwnagotchi and change it in the settings
      • The Blue LED is from the embedded battery in the Pwnagtochi casing. This LED only turns on when the battery is being used
      Chiedi a FixBot
      Aggiungi Commento
    2. Pwnagotchi Teardown, Removing the Outer Case: passo 2, immagine 1 di 1
      • This step is Optional if you have a Pwnagotchi without a case.
      • If possible, remove the outer casing of your Pwnagotchi. For this guide, our case has a removeable top and bottom so we can access the screen and battery
      Chiedi a FixBot
      Aggiungi Commento
    3. Pwnagotchi Teardown: passo 3, immagine 1 di 2 Pwnagotchi Teardown: passo 3, immagine 2 di 2
      • With the Top cover removed, we can see that the Pwnagotchi has a Waveshare E-Ink Display.
      • This area is covered by the 3D printed case to protect the display ribbon and electronics
      • The GIPO Ports all go inside the raspberry Pi Zero, you will not need the white, 8-pin header (It can be removed if you want to have a slimmer pwnagotchi)
      • This Pwnagotchi utilizes the V2 Display because of the better refresh rate. There is less ghosting on the display compares to the V1
      Chiedi a FixBot
      Aggiungi Commento
    4. Pwnagotchi Teardown: passo 4, immagine 1 di 1
      • Removing the bottom case, there is a 3.7 Volt Lithium-Ion Battery powering the device with 1200mAh
      • When building the Pwnagotchi, you can use a battery (shown in the picture) or an external power source, such as an external battery pack
      Chiedi a FixBot
      Aggiungi Commento
    5. Pwnagotchi Teardown: passo 5, immagine 1 di 1
      • Upon removing the E-Ink Display, there is a Raspberry Pi Zero WH that runs the Operating System for the Pwnagotchi
      • The SD card runs the OS behind the Scenes, and for this case, is protected from accidently slipping out or being removed
      Chiedi a FixBot
      Aggiungi Commento
    6. Pwnagotchi Teardown: passo 6, immagine 1 di 1
      • To access the battery, we will be removing (4) of the M3 screws holding the Pi down with a Phillips head screwdriver
      Chiedi a FixBot
      Aggiungi Commento
    7. Pwnagotchi Teardown: passo 7, immagine 1 di 1
      • Once the screws are removed, separate the Pi and the PiSugar Battery
      • These Pins connect to the Pi and provide power for the Device
      Chiedi a FixBot
      Aggiungi Commento
    8. Pwnagotchi Teardown: passo 8, immagine 1 di 1
      • The battery is connected to the board via magnet and can be separated from the board to get a better look at the workings
      • Be careful when separating the magnets as there are two power wires connecting the wire and the board
      Chiedi a FixBot
      Aggiungi Commento
    9. Pwnagotchi Teardown: passo 9, immagine 1 di 1
      • There are different connectors for this build, to better understand them, this is what they are used for:
      • Connectors/Ports on the raspberry pi zero
      • Mini HDMI Port
      • USB OTG (On-The-Go) Port
      • Power Port (Rated around 5-5.25V)
      • Ports/Connectors on the battery
      • Battery Power port
      • Battery Power Switch
      Chiedi a FixBot
      Aggiungi Commento
    10. Pwnagotchi Teardown: passo 10, immagine 1 di 1
      • This is the Pwnagotchi completely taken apart
      Chiedi a FixBot
      Aggiungi Commento
Medical
Membro da: 01/11/18
3.348 Reputazione
2 guide realizzate
Team Pwnagotchi Membro di Team Pwnagotchi
Community
Membro di 1
24 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 12
Ultimi 30 giorni: 53
Tutti i Tempi: 2,893
