Salta al contenuto principale
Prusa i3 Mk2 Nozzle Replacement
Cosa ti serve
  1. Prusa i3 Mk2  Nozzle Replacement, Nozzle: passo 1, immagine 1 di 3 Prusa i3 Mk2  Nozzle Replacement, Nozzle: passo 1, immagine 2 di 3 Prusa i3 Mk2  Nozzle Replacement, Nozzle: passo 1, immagine 3 di 3
    • Turn the 3D printer on using the power switch.
    • Move the head to the highest position on the Z axis. This provides working room to access the head.
    • Heat the nozzle up. This step depends on what type of filament is currently in the machine (e.g. 190 for PLA, 220 for ABS).
    • Remove filament from the 3D printer.
    • Clean off the old nozzle with tweezers.
  2. Prusa i3 Mk2  Nozzle Replacement: passo 2, immagine 1 di 3 Prusa i3 Mk2  Nozzle Replacement: passo 2, immagine 2 di 3 Prusa i3 Mk2  Nozzle Replacement: passo 2, immagine 3 di 3
    • Remove the 1 X M3 Bolt holding on the fan shroud on the outlet of the fan.
    • Remove the fan shroud.
    • Remove the 2 X M3 Bolts holding on the blower fan.
    • Remove the fan and place it in a safe location.
    • The wires are still attached to the fan, be careful to not break the connectors.
  3. Prusa i3 Mk2  Nozzle Replacement: passo 3, immagine 1 di 1
    • Remove the 2 X M3 Bolts from the Extruder Plate.
  4. Prusa i3 Mk2  Nozzle Replacement: passo 4, immagine 1 di 2 Prusa i3 Mk2  Nozzle Replacement: passo 4, immagine 2 di 2
    • Remove the two M3 Bolts that are holding on the Extruder Cooling Fan.
    • Remove the Extruder Plate carefully, and avoid touching the hot metal print head.
    • Leave one bolt on the back of the fan so that the fan stays attached to the rest of the assembly.
  5. Prusa i3 Mk2  Nozzle Replacement: passo 5, immagine 1 di 1
    • Make sure the nozzle is heated up before doing this step to prevent damage to the print head.
    • Use an adjustable crescent wrench and a 7mm wrench or socket to remove the old nozzle.
  6. Prusa i3 Mk2  Nozzle Replacement: passo 6, immagine 1 di 3 Prusa i3 Mk2  Nozzle Replacement: passo 6, immagine 2 di 3 Prusa i3 Mk2  Nozzle Replacement: passo 6, immagine 3 di 3
    • Screw in the new nozzle using a socket to get the threads started.
    • Use a crescent wrench and a 7mm wrench or socket to tighten a quarter turn past hand tight.
    • Do not over tighten. Damage to the nozzle or print head could occur.
    • Insert some new filament and push it through to test the connection.
Conclusione
To reassemble your device, follow these instructions in reverse order. Once reassembled, print a test print to ensure the replaced nozzle is not leaking.
Altre 6 persone hanno completato questa guida.
Aubrey Woern
Membro da: 09/24/17
253 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 53
Tutti i Tempi: 10,184
