Salta al contenuto principale
Prusa i3 MK3 Y-Axis Bearings Replacement
Cosa ti serve
  1. Prusa i3 MK3 Y-Axis Bearings Replacement, Y-Axis Bearings: passo 1, immagine 1 di 3 Prusa i3 MK3 Y-Axis Bearings Replacement, Y-Axis Bearings: passo 1, immagine 2 di 3 Prusa i3 MK3 Y-Axis Bearings Replacement, Y-Axis Bearings: passo 1, immagine 3 di 3
    • Orient the printer so that the screen is facing to the left.
    • Using the On/Off button, switch the printer into the Off position.
    • Ensure your printer is off by visually inspecting the screen. If the screen is not lit up, your printer is off.
    • Ensure the printer has cooled to room temperature before beginning disassembly.
  2. Prusa i3 MK3 Y-Axis Bearings Replacement: passo 2, immagine 1 di 2 Prusa i3 MK3 Y-Axis Bearings Replacement: passo 2, immagine 2 di 2
    • Orient the printer so that the screen is facing you.
    • Move the X-axis carriage to the highest Z-axis height for optimal accessibility.
    • Remove magnetic build plate.
  3. Prusa i3 MK3 Y-Axis Bearings Replacement: passo 3, immagine 1 di 2 Prusa i3 MK3 Y-Axis Bearings Replacement: passo 3, immagine 2 di 2
    • Remove the nine 2.5mm X 12mm flat-head countersink screws from the heat bead.
    • Lift and set the heat bed aside to access the heat bed mounting bracket.
  4. Prusa i3 MK3 Y-Axis Bearings Replacement: passo 4, immagine 1 di 1
    • Orient the printer so that the screen is facing away from you.
    • Remove the two 2.5mm X 10mm socket head screws holding the Y-axis belt motor bracket.
    • During reassembly, these screws will be used to properly tension the Y-axis belt.
  5. Prusa i3 MK3 Y-Axis Bearings Replacement: passo 5, immagine 1 di 2 Prusa i3 MK3 Y-Axis Bearings Replacement: passo 5, immagine 2 di 2
    • Use the side cutters to cut and remove the four zip ties that secure the Y-axis rods.
  6. Prusa i3 MK3 Y-Axis Bearings Replacement: passo 6, immagine 1 di 2 Prusa i3 MK3 Y-Axis Bearings Replacement: passo 6, immagine 2 di 2
    • Lift the heat bed mounting bracket assembly from the printer.
    • Remove the Y-axis rods from the heat bed mounting bracket assembly.
  7. Prusa i3 MK3 Y-Axis Bearings Replacement: passo 7, immagine 1 di 1
    • Rotate the heat bed mounting bracket assembly to access the bottom side.
    • Remove the Y-axis belt from the Y-axis belt grip.
    • Remove the heat bed mounting bracket assembly and set it aside to complete the next steps.
  8. Prusa i3 MK3 Y-Axis Bearings Replacement: passo 8, immagine 1 di 2 Prusa i3 MK3 Y-Axis Bearings Replacement: passo 8, immagine 2 di 2
    • Orient the heat bed mounting bracket so that you are looking at the top side.
    • Use the 5.5mm nut driver to remove the six 5.5mm u-bolt nuts.
    • Orient the heat bed mounting bracket so that you are looking at the bottom side.
    • Remove the three sets of U-bolts and Y-axis bearings.
  9. Prusa i3 MK3 Y-Axis Bearings Replacement: passo 9, immagine 1 di 3 Prusa i3 MK3 Y-Axis Bearings Replacement: passo 9, immagine 2 di 3 Prusa i3 MK3 Y-Axis Bearings Replacement: passo 9, immagine 3 di 3
    • During reassembly, grease the Y-axis bearings with the PRUSA Lubricant Applicator.
    • When reinstalling the Y-axis bearings, the balls inside the bearings should form a diagonal "X", not a vertical "+".
Conclusione
To reassemble your device, follow these instructions in reverse order. Use Step 9 for reference.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 180
