Introduzione
If you are experiencing layer shifting issues or having issues with the function of the X-axis belt, you may need to replace it. To replace the X-axis belt in your PRUSA i3 MK3, follow the steps in this guide. With heavy use, replacing the belt every 6-8 months is recommended. Ensure that you do not lose any of the parts or socket head screws that are removed during replacement.
Cosa ti serve
Orient the printer so that the screen is facing to the left.
Using the On/Off button, switch the printer into the Off position.
Ensure your printer is off by visually inspecting the screen. If the screen is not lit up, your printer is off.
Orient the printer so that the screen is facing you.
Loosen the 2.5mm X 18mm tension set screw.
Loosen the two 2.5mm X 18mm socket head screws on the right, holding on to the X-axis motor.
Slightly loosen the 2.5mm X 18mm pivot screw on the left. This screw will act as a pivot for the X-axis motor.
Pivot the motor to release the tension on the belt.
Orient the printer so that the screen is facing away from you.
Loosen the 2.5mm X 18mm and 2.5mm X 30mm socket head screws that hold the belt in. You do not need to remove these screws.
Remove the belt from the belt grips by pulling the belt towards you.
Un-feed the belt from its track. The belt should now be removed.
To reassemble your device, follow these instructions in reverse order. During reassembly, do not over-tighten the socket head screws. Reference Step 4 for proper belt tension.
