Introduzione
This guide will demonstrate how to remove and replace the Protocol Vento Wi-Fi antenna.
Cosa ti serve
To get into the drone, twelve total screws need to be removed:
Ten 5.7mm Phillips #000 screws from the bottom of the drone body.
Two 4.5mm Phillips #000 screws at the front of the drone.
Remove the two 4.9mm Phillips #000 screws securing the camera to the front of the drone body.
Unscrew the four 4.9mm Phillips #000 corner screws that are securing the motherboard’s black base to the drone.
Hold the drone’s shell with both hands so that the inside of the shell is facing you.
Gently flex the shell outward, so that the two latches (holding the antenna in place) move apart slightly.
At the same time, push the antenna from the back of the drone towards you until it releases from the latches.
Altre 3 persone hanno completato questa guida.
