Salta al contenuto principale
Protocol Vento Motor Replacement
Cosa ti serve
  1. Protocol Vento Motor Replacement, Battery: passo 1, immagine 1 di 1
    • Grasp the tail end of the drone where the lip of the battery protrudes.
  2. Protocol Vento Motor Replacement: passo 2, immagine 1 di 1
    • Pull away from the drone to remove the battery.
    • Do not attempt any repairs or replacements before removing the battery from the drone.
  3. Protocol Vento Motor Replacement, Propeller: passo 3, immagine 1 di 1
    • Place a prying tool under the base of the propeller.
  4. Protocol Vento Motor Replacement: passo 4, immagine 1 di 2 Protocol Vento Motor Replacement: passo 4, immagine 2 di 2
    • Use a moderate amount of force to pry the propeller out of its base. The propeller should pop off.
  5. Protocol Vento Motor Replacement, Motor: passo 5, immagine 1 di 1
    • Unscrew the 4.9mm Phillips #000 screw that is located at the end of the drone's arm.
  6. Protocol Vento Motor Replacement: passo 6, immagine 1 di 2 Protocol Vento Motor Replacement: passo 6, immagine 2 di 2
    • Hold the base of the arm while gently pulling the motor cover away from the arm.
    • Do not pull too hard because there are wires attaching the motor to the drone. Do not sever the wires.
  7. Protocol Vento Motor Replacement: passo 7, immagine 1 di 2 Protocol Vento Motor Replacement: passo 7, immagine 2 di 2
    • Gently pull the motor out from the plastic cover.
    • Do not squeeze or pull too hard, as to not damage the motor connection.
  8. Protocol Vento Motor Replacement: passo 8, immagine 1 di 2 Protocol Vento Motor Replacement: passo 8, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • The motor’s blue and red wires are secured via a white clip. This clip is inserted into a slot in the drone’s leg.
    • Grasp the clip’s edges with a pair of tweezers and pull outward.
    • Do not pull directly on the wires, as to not separate the wires from the clip.
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team S1-G2, Leahy Spring 2018 Membro di USF Tampa, Team S1-G2, Leahy Spring 2018
USFT-LEAHY-S18S1G2
4 Membri
6 Guide realizzate
2Commenti sulla guida
Please send me motor description
suresh virji - Replica
send me protocol vento motor
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 762
