Salta al contenuto principale
Protocol Slipstream EVO Propeller blades Replacement
Cosa ti serve
  1. Protocol Slipstream EVO Propeller blades Replacement, Propeller blades: passo 1, immagine 1 di 1
    • With the drone flat on the ground identify which propeller you will be replacing.
  2. Protocol Slipstream EVO Propeller blades Replacement: passo 2, immagine 1 di 2 Protocol Slipstream EVO Propeller blades Replacement: passo 2, immagine 2 di 2
    • Using two fingers, place them on each side of the propellor near the middle.
    • Pull straight up with force. The propellor will feel as if it will not come off but do not be scared to use some muscle.
    • Warning: Pulling at an angle will result in bending the motor's needle.
  3. Protocol Slipstream EVO Propeller blades Replacement: passo 3, immagine 1 di 3 Protocol Slipstream EVO Propeller blades Replacement: passo 3, immagine 2 di 3 Protocol Slipstream EVO Propeller blades Replacement: passo 3, immagine 3 di 3
    • Checking the underside of the propeller there will be a letter which will correspond with each side of the drone
    • On the corner of the drone where the blade mounts onto the motor you will see which blade you should be using.
    • Warning: Failure to match the propeller blade to the right motor may result in the drone not flying.
    • Lining up the propeller blade with the needle, push down until the propeller is flushed.
Conclusione
Michael Dang
Membro da: 04/10/17
301 Reputazione
3 Guide realizzate
UW Tacoma, Team S3-G3, Liner Spring 2017 Membro di UW Tacoma, Team S3-G3, Liner Spring 2017
UWT-LINER-S17S3G3
4 Membri
3 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 607
