Introduzione
This guide will be showing you how to replace the propeller blades on the Slipstream EVO.
Cosa ti serve
With the drone flat on the ground identify which propeller you will be replacing.
Checking the underside of the propeller there will be a letter which will correspond with each side of the drone
On the corner of the drone where the blade mounts onto the motor you will see which blade you should be using.
Warning: Failure to match the propeller blade to the right motor may result in the drone not flying.
Lining up the propeller blade with the needle, push down until the propeller is flushed.
