Salta al contenuto principale
Protocol Slipstream EVO Propeller Guards Replacement
Cosa ti serve
  1. Protocol Slipstream EVO Propeller Guards Replacement, Propeller Guards: passo 1, immagine 1 di 1
    • With the drone flat on the ground, identify which propeller guard you will be replacing.
    • The front of the drone is where there are no wires exposed.
  2. Protocol Slipstream EVO Propeller Guards Replacement: passo 2, immagine 1 di 2 Protocol Slipstream EVO Propeller Guards Replacement: passo 2, immagine 2 di 2
    • With the plastic opening tool, pry the side of the guard closest to the front or the back of the drone depending on where you decided to start from.
    • After prying off one side of the guard, pushing down on the same side will release the other side of the clip.
    • Repeat this step for the following side as needed.
  3. Protocol Slipstream EVO Propeller Guards Replacement: passo 3, immagine 1 di 2 Protocol Slipstream EVO Propeller Guards Replacement: passo 3, immagine 2 di 2
    • With the replacement guard line up the clips and push the clips into place.
    • After the guard has been attached to the drone, pinch the clips as you push the guards to ensure they are secured.
Conclusione
Michael Dang
Membro da: 04/10/17
301 Reputazione
3 Guide realizzate
UW Tacoma, Team S3-G3, Liner Spring 2017 Membro di UW Tacoma, Team S3-G3, Liner Spring 2017
UWT-LINER-S17S3G3
4 Membri
3 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 236
