Cosa ti serve
On the bottom of the drone unscrew the screws next to the battery, using the screwdriver provided.
The picture shows one of the screws you will be removing, the other screw is directly across from the one being presented.
Tip: Removing the screws will loosen the frame of the drone allowing the battery to be removed easier. If you do not want to remove the screws skip to step 2.
Quasi finito!
Conclusione
