Salta al contenuto principale
Protocol Kaptur GPS Virtual Reality Lens Replacement
Cosa ti serve
  1. Protocol Kaptur GPS Virtual Reality Lens Replacement, Virtual Reality Lens: passo 1, immagine 1 di 3 Protocol Kaptur GPS Virtual Reality Lens Replacement, Virtual Reality Lens: passo 1, immagine 2 di 3 Protocol Kaptur GPS Virtual Reality Lens Replacement, Virtual Reality Lens: passo 1, immagine 3 di 3
    • Remove the phone slide from the virtual reality goggles.
    • Take the outside cover off using the plastic opening tool.
  2. Protocol Kaptur GPS Virtual Reality Lens Replacement: passo 2, immagine 1 di 3 Protocol Kaptur GPS Virtual Reality Lens Replacement: passo 2, immagine 2 di 3 Protocol Kaptur GPS Virtual Reality Lens Replacement: passo 2, immagine 3 di 3
    • Remove each screw from its place.
    • Remove four 6mm Phillips head screws.
    • Remove twelve 7mm Phillips head screws.
    • Pull out each bracket so you can see the full lens case.
  3. Protocol Kaptur GPS Virtual Reality Lens Replacement: passo 3, immagine 1 di 3 Protocol Kaptur GPS Virtual Reality Lens Replacement: passo 3, immagine 2 di 3 Protocol Kaptur GPS Virtual Reality Lens Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Remove the adjustable lens lever on top of the virtual reality lens.
    • Using tweezers, you will need to separate the tooth gears and remove them so the lens can fall freely out.
    • Pull the lens case out from the front of the headset.
  4. Protocol Kaptur GPS Virtual Reality Lens Replacement: passo 4, immagine 1 di 2 Protocol Kaptur GPS Virtual Reality Lens Replacement: passo 4, immagine 2 di 2
    • With a little force, push the lens from outside in to break the lens out of the case. This will get the lens out.
    • Now replace the lens with a new one and follow the steps in reverse order to put the lens back!
Conclusione
Austin Fedie
Membro da: 02/15/18
168 Reputazione
1 Guida realizzata
UW Stout, Team S8-G6, Ogden Spring 2018 Membro di UW Stout, Team S8-G6, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G6
3 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 401
