Introduzione
This guide will explain how to replace a motor of the Protocol Kaptur GPS drone.
Cosa ti serve
The battery is accessible through the back of the drone.
Press the tabs on both sides of the white stripe to pull the battery out.
Remove the 4x 7mm Phillips head screws on the outside of the shell, and the 2x 5mm Phillips head screws from the middle, then remove the back part of the housing.
Remove the two hidden screws at the bottom, and the white power button.
Remove the motor by unsoldering the cords from the main circuit board.
Altre 9 persone hanno completato questa guida.
11 Commenti
What size and rpm does it take, but also is there a way to upgrade the motors for more punch?
Thank you.for your information and time to make my grandson
What size is the main gear??
2.0
I believe
Anyone else having a problem with the props twisting on the shaft during flight
Have you checked the teeth on the prop gear and the teeth on the motor gear? Chances are its one of the two components. If it’s the motor gear , you can buy a set of four motors from eBay for like $9. Just replace motor, if it’s the prop gear, replace the gear. If it’s neither of the two, stop what you’re doing and go on offer up and just buy a freaking DJI Mavic Pro . You can get a used one for probably the same price you paid for this junk new , so, ya.
Wise Guy -
Yes mine , my Kaptur got loose from me and hit hit the bottom of a pickup truck and the small plastic piece that the prop screws to come loose from the motor shaft and the motor won’t turn no ,where can I get a new motor please ?
Is it possible to use electric tape, split and join the specific motor wires with one another, And not have to F with any soldering?
Can we upgrade the motors on protocol kaptur ?
Thanks for the info! This is so awesome! I'll remember this site
any1 have a image of the gyro wiriring
