Salta al contenuto principale
Introduzione
This guide will show where to find the battery and how to replace it. If the drone does not have power or the battery is damaged, use this guide to help you.
Parti
Nessuna parte specificata.
  1. The battery is accessible through the back of the drone. Press the tabs on both sides of the white stripe to pull the battery out.
    • The battery is accessible through the back of the drone.
    • Press the tabs on both sides of the white stripe to pull the battery out.
  2. Now that the battery is out, remove the screws starting with the four smaller ones on the top part of the battery. After this, remove the last four on the side. Make sure to keep track of where each screw came from. There should be one 7 mm Phillips head screw, three 6 mm Phillips head screws, and four 5 mm Phillips head screws. There is another screw that is located where the arrow is pointed. You will need to take the other screws out first before you can get to this one.
    • Now that the battery is out, remove the screws starting with the four smaller ones on the top part of the battery. After this, remove the last four on the side. Make sure to keep track of where each screw came from.
    • There should be one 7 mm Phillips head screw, three 6 mm Phillips head screws, and four 5 mm Phillips head screws.
    • There is another screw that is located where the arrow is pointed. You will need to take the other screws out first before you can get to this one.
  3. Kit per Apple Watch
    Screen and battery repairs just got easier.
    Acquista ora
    Kit per Apple Watch
    Acquista ora
  4. Remove the top piece, and gently pry the two halves apart. Divide the sticker if necessary. Remove the top piece, and gently pry the two halves apart. Divide the sticker if necessary.
    • Remove the top piece, and gently pry the two halves apart. Divide the sticker if necessary.
  5. The battery is now removable from its container. During reassembly, make sure the outlet is returned to its holder and faces the correct direction.
    • The battery is now removable from its container.
    • During reassembly, make sure the outlet is returned to its holder and faces the correct direction.
Conclusione
Altre 3 persone hanno completato questa guida.
Connor Woitte
Membro da: 15/02/2018
624 Reputazione
3 Guide realizzate
UW Stout, Team S8-G6, Ogden Spring 2018 Membro di UW Stout, Team S8-G6, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G6
3 Membri
4 Guide realizzate
Any chance someone’s found a new internal battery for these? Stock ones break down incredibly fast and don’t want to take a charge
Jeff - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 41
Tutti i Tempi: 390
