Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
This guide will walk you through how to remove the motor propeller from the drone. This is a very simple process, and minimal tooling is required. This guide is useful for replacing blades that may have been damaged.
Parti
Nessuna parte specificata.
  1. Remove the chrome shaft cover by lightly pulling it away from the drone.
    • Remove the chrome shaft cover by lightly pulling it away from the drone.
  2. Using a Phillips #000 screwdriver, remove the 7mm screw from the propeller stop.
    • Using a Phillips #000 screwdriver, remove the 7mm screw from the propeller stop.
    • Be sure to apply adequate pressure when removing the screw to prevent stripping it out.
  3. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Remove the propeller stop from shaft by lightly pulling it away from the drone.
    • Remove the propeller stop from shaft by lightly pulling it away from the drone.
  5. Remove the propeller from shaft by lightly pulling it away from the drone.
    • Remove the propeller from shaft by lightly pulling it away from the drone.
Conclusione
UW Stout, Team S8-G4, Ogden Spring 2018 Membro di UW Stout, Team S8-G4, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G4
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 120
