Introduzione
This guide will walk you through how to remove the pinion gear from the motor shaft. Minimal tooling is required on the prerequisite steps, but removing the pinion gear itself requires no tools. Removing the pinion gear is very easy and should only take a few seconds to complete.
Cosa ti serve
Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
Lift the pinion gear off the motor shaft by lightly pulling it away from the drone.
2 Commenti
where can i get pinion gears at
where can i purchase pinion gears
