Salta al contenuto principale
Protocol Galileo Stealth Housing Replacement
Cosa ti serve
  1. Protocol Galileo Stealth Housing Replacement, Propeller: passo 1, immagine 1 di 1
    • Remove the chrome shaft cover by lightly pulling it away from the drone.
  2. Protocol Galileo Stealth Housing Replacement: passo 2, immagine 1 di 1
    • Using a Phillips #000 screwdriver, remove the 7mm screw from the propeller stop.
    • Be sure to apply adequate pressure when removing the screw to prevent stripping it out.
  3. Protocol Galileo Stealth Housing Replacement: passo 3, immagine 1 di 1
    • Remove the propeller stop from shaft by lightly pulling it away from the drone.
  4. Protocol Galileo Stealth Housing Replacement: passo 4, immagine 1 di 1
    • Remove the propeller from shaft by lightly pulling it away from the drone.
  5. Protocol Galileo Stealth Housing Replacement, Housing: passo 5, immagine 1 di 2 Protocol Galileo Stealth Housing Replacement, Housing: passo 5, immagine 2 di 2
    • Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
    • Take care to place the screws in a safe place to prevent losing them.
  6. Protocol Galileo Stealth Housing Replacement: passo 6, immagine 1 di 1
    • Separate the upper and lower housing units by lightly pulling the two housing units apart.
Conclusione
UW Stout, Team S8-G4, Ogden Spring 2018 Membro di UW Stout, Team S8-G4, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G4
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 147
