Salta al contenuto principale
Protocol Galileo Motor Replacement
Cosa ti serve
  1. Protocol Galileo Motor Replacement, Battery: passo 1, immagine 1 di 1
    • Find door on the underside of drone. Open the door.
  2. Protocol Galileo Motor Replacement: passo 2, immagine 1 di 2 Protocol Galileo Motor Replacement: passo 2, immagine 2 di 2
    • Carefully pull out battery, pulling out wires first.
  3. Protocol Galileo Motor Replacement: passo 3, immagine 1 di 1
    • Disconnect the connecter.
    • When reconnecting, remember to match up the black wire with the black wire and the red with red.
  4. Protocol Galileo Motor Replacement, Propeller: passo 4, immagine 1 di 2 Protocol Galileo Motor Replacement, Propeller: passo 4, immagine 2 di 2
    • Use the heavy duty spudger tool to pry off metal caps by pushing the spudger up into the cap.
  5. Protocol Galileo Motor Replacement: passo 5, immagine 1 di 1
    • Twist the white spindle sleeve counter clockwise to align locking pin inside with the opening.
  6. Protocol Galileo Motor Replacement: passo 6, immagine 1 di 1
    • Use tweezers to remove locking pin.
  7. Protocol Galileo Motor Replacement: passo 7, immagine 1 di 1
    • Pull off white spindle sleeve.
    • Take note of which side of the spindle sleeve is the top.
  8. Protocol Galileo Motor Replacement: passo 8, immagine 1 di 2 Protocol Galileo Motor Replacement: passo 8, immagine 2 di 2
    • Pull off propeller.
  9. Protocol Galileo Motor Replacement, Top Shell: passo 9, immagine 1 di 3 Protocol Galileo Motor Replacement, Top Shell: passo 9, immagine 2 di 3 Protocol Galileo Motor Replacement, Top Shell: passo 9, immagine 3 di 3
    • Remove Blade Guards by unscrewing two 13 millimeter screws using Philips #0. Pull out the guards. Repeat the steps for the other three corners.
  10. Protocol Galileo Motor Replacement: passo 10, immagine 1 di 2 Protocol Galileo Motor Replacement: passo 10, immagine 2 di 2
    • Unscrew two 9 mm screws located inside the legs. Repeat the same procedure for the other three legs
  11. Protocol Galileo Motor Replacement: passo 11, immagine 1 di 3 Protocol Galileo Motor Replacement: passo 11, immagine 2 di 3 Protocol Galileo Motor Replacement: passo 11, immagine 3 di 3
    • Unplug the camera wire.
    • Press the hold release button and slide out the camera module away from the button.
  12. Protocol Galileo Motor Replacement: passo 12, immagine 1 di 2 Protocol Galileo Motor Replacement: passo 12, immagine 2 di 2
    • Remove the motor protection cover by unscrewing two 9 mm screws using Philips #0. When the screws are off, use your fingers to pull the motor protection cover off. Repeat the procedure for the other three arms.
  13. Protocol Galileo Motor Replacement: passo 13, immagine 1 di 3 Protocol Galileo Motor Replacement: passo 13, immagine 2 di 3 Protocol Galileo Motor Replacement: passo 13, immagine 3 di 3
    • Unclip the motor cable from the shells housing using two pry tools. Repeat the same procedure for the other three arms.
  14. Protocol Galileo Motor Replacement: passo 14, immagine 1 di 1
    • Remove 3 9mm screws around the motor housing. Repeat the steps for the three other arms.
  15. Protocol Galileo Motor Replacement: passo 15, immagine 1 di 2 Protocol Galileo Motor Replacement: passo 15, immagine 2 di 2
    • Remove four 9 mm screws located where the legs originally are placed. (Use a thin head screwdriver)
  16. Protocol Galileo Motor Replacement: passo 16, immagine 1 di 3 Protocol Galileo Motor Replacement: passo 16, immagine 2 di 3 Protocol Galileo Motor Replacement: passo 16, immagine 3 di 3
    • Cut the yellow strips using a scalpel. Pry open the casing using pry tools working gently around the corners.
  17. Protocol Galileo Motor Replacement, Pinion Gear: passo 17, immagine 1 di 1
    • Remove the motor assembly from the bottom shell.
  18. Protocol Galileo Motor Replacement: passo 18, immagine 1 di 2 Protocol Galileo Motor Replacement: passo 18, immagine 2 di 2
    • Slide the pinion gear off of the motor assembly.
  19. Protocol Galileo Motor Replacement, Motor: passo 19, immagine 1 di 2 Protocol Galileo Motor Replacement, Motor: passo 19, immagine 2 di 2
    • Remove the two 4mm Philips screws from the motor.
    • Separate the motor from the plastic motor holder.
Conclusione
Thomas Ramey
Membro da: 02/03/17
301 Reputazione
3 Guide realizzate
UW Tacoma, Team 2-3, Rose Winter 2017 Membro di UW Tacoma, Team 2-3, Rose Winter 2017
UWT-ROSE-W17S2G3
4 Membri
5 Guide realizzate
Un commento
what I need to know is where can I buy the plastic motor holder. This would be for a Galileo stealth drone. can someone please help me with this. markkermoyan@gmail.com
mark kermoyan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 679
